1 Attachment(s)
Transmission doesn't recognize proper speed after 0411 swap
I have a 1999 Yukon that I just performed a 411 swap in. I've checked all my wiring and the transmission was working fine with the blackbox PCM just a few weeks ago.
After performing the swap the transmission didn't want to shift properly at all, and I was getting P0715 code. After disabling that code in Engine Diag, the transmission shifted somewhat better, but it still has problems. It's missing shift points, and at times, missing whole gears. I did a test at WOT and 1-2 was fine, it missed gear 3 entirely. There was no drive at all until I came off the throttle and it found gear 3, and it never shifts to OD, at all. I did a test with a GPS up, come to find that the Speedo is wrong, so I redid my calculations for the Speedo. For Trans revolutions per mile, I calculated this:
Tire Circumference: 99.1" (not factory tires)
Final Drive: 3.42
Inches per mile: 63360
63360/99.1 = 639.35418 tire rotations per mile
639.35418 * 3.42 = 2,186.5913 trans rotations per mile.
Now the speedo and GPS agree with each other, but with the scanner plugged in, I can see that the tranny is 16% off @ 50mph. Cruising at 50mph, the vehicle speed, according to the transmission, was 42mph. The transmission speed reading low may account for why it's missing shift points, but I can't see why it would never shift in to OD. I've attached my current file, I've never done a swap like this before and am in a bit over my head. Any help would be appreciated.
Thank you!
