4 Attachment(s)
MPVI standalone logging issue
Can anyone tell me why my logs for commanded eq (lambda) are the opposite of each other when I log with my laptop and when I log standalone? When I log data with my laptop connected everything works as I want it to. For example, commanded eq of .5 shows .5 in the channels and on the graphs I have setup. When I log with the standalone my commanded eq is off. When the commanded eq is .5 it shows 2.0 on the channels and graphs. WTF?
I tried reloading the config to the scanner. Its almost as if it logs phi instead of lambda... I even tried logging phi in the channels list and reloading the config. Still showed the opposite! commanded eq (phi) of 2.0 and read .5. Tried 4.0, 4.2, and the newest beta.
This is on my 05 GTO with E40 pcm. Attached are my config and log.
