Seems to have fixed itself after i went through the datalogging settings the second time, I was able to successfully log, thanks!
How do you pick your own channels. The set up only has write channels, read channels, and erase channels. When it click write channels it writes default channels. When you click read channels it reads and it has the default channels. It is mostly useless if you can't pick your own channels to log.
Thanks I will do that. When it was loading only the default channels I didn't have it hooked up to the car. Just had the mpvi2 hooked to the laptop.
