There are improvements to be made over that tune all around honestly. I glanced over it and checked the log of the pull. It's so much richer than it needs to be at full throttle leaving a lot of power to be had and depends on O2 sensors to add a lot of fuel to keep cruising AFR where it should be. The way boost moves around WOT I think you might have some belt slip. Part throttle not wanting to make much boost and fluttering boost is a common thing and typically tuning related though. I am not sure if your cam is locked out or not either but based on tune I think they might have installed cam locked instead of with a limiter. Not what I typically recommend but with good cam specs not really a big deal.
I have spent a lot of time testing on 392 with forged internals and PD blowers and can get it running good and driving really nice if you're interested in setting up a remote tune. You already have HP Tuners and wideband and are familiar enough to get logs and flash tunes so would be a pretty easy process. Should be able to get a setup like that running low 10s or better in the 1/4 on race gas and good tire and driving nice.
Send me a message at Facebook.com/TBRTuning or
[email protected] if you're interested.
