2008 Charger Drivetrain Swap Transmission Code P0733 - Gear 3 Incorrect Ratio
Hey everyone, I am new to Dodge Tuning and I am currently having a problem with a car I am tuning. A 2008 Charger drivetrain has been swapped into another vehicle and it is creating all sorts of headaches for me. The factory dash and most components are in the new vehicle. The engine is built and is supercharged. The transmission is also built. I have been able to get the vehicle to start up and idle well. I have also rough tuned part throttle. Beyond that the car will rev in neutral, but will not rev when moving. I am getting code P0733 which is "Gear 3 Incorrect Ratio", which I feel is throwing it into limp mode. Any thoughts on what might be causing this? Could it be a transmission issue? And how would I diagnose it? I don't feel any noticeable slip when driving it. At first I thought it was a traction control issue, since I initially had the car on the dyno. I pulled the car off the dyno, and the same thing occurs going down the road. 3000 RPM seems to be the max and the pedal feels dead. I found out the vehicle has had the ABS removed and that has given me some concern since the traction control would be effected by this. The traction control lights are lit on the dash. I believe I have turned off the traction control in the tune. Any insight would be appreciated.
Thanks.
