2 Attachment(s)
Timing pulled at 2600 rpm 5lbs boost. 0 degrees timing under load
Attachment 86865
Gradually working my way to 50% throttle & to 2500-2600 rpms, maybe 5 lbs boost, my spark goes from a commanded of 12 degrees right to 0. Not so convinced that its burst knock because theres no real quick sudden change in airflow. I'm running this on 93 octane.
6.0, turbo, mild cam.
Also is it crazy to think maybe my exhaust is messing with the knock sensors? My exhaust exits the fender and is somewhat noisy.
Low and High spark tables are the same.
I don't remember the gaps of the plugs but they was adjusted for boost when installed.
I'm going to try and log Knock Retard and also Burst Knock. During my log I posted it didn't record Knock Retard anywhere.
Heres the latest log.
Attachment 86866
