does anyone know how to setup real time tuning in vcm scanner 3.4?
interested
if PCM allows You need to apply custom OS and then in Scanner will appear new icon when scanning
best regards
Yeah I'm pretty sure the basic's haven't changed the help file www.hptuners.com/help has a guide on how to use RTT step by step.
If you aren't running a gen 3 GM ECM then you won't have RTT. I've answered this on a few forums recently.. RTT does not exist for gen 4 or 5 GM's or any other OEM's
Can RTT be used with the Standard MPVI or only the pro?
Either.
mine scanner locks up and closes wen loading the rtt tables not sure why
I'm running gen 3 pcm and my hp tuners doest have the box for RTT in general
It's not available on every single operating system even if it's a GEN 3 computer.
If you don't see it listed in the OS tab, then you don't have it.
What's the Auto-Tuning mentioned in the Help file?
Well get on it!
i doubt that is ever going to be a possibility. The "auto tune" features of aftermarket ecus function somewhat o.k. Because the ecus are extremely simplified. Think atari vs xbox. An aftermarket ecu simply targets a specific idle rpm, specific timing, and specific fuel. Oem ecus are extremely complex, with airflow modeling, torque modeling, etc. This would require a ton of dumbing down of the ecus, which kind of defeats the purpose.
Rtt isnt a feature thats unlocked, its a feature that is added. Its a patch that is added into the code.
