is there a way to change this manually? i was thinking it would be nice to rename tunes based on type of fuel or vehicle, or whatever.
i know sct can change it. so I'm asking can hptuners change OSID/strategy name?
If you did that then you would stop the scanner from being able to log pids that are mapped to that strategy
Was there ever a solution to this? I'm running into the same issue....
Ah, very nice! That I was not aware, thank you! I do actually know the OEM ID so I will give that a try.
Look for it under Vehicle>Vehicle Profiles>Vehicle Profile Editor. Select your vehicle and enter the correct ID under User OS.
Will do!
Is there any way to get around this to use the Editor? Being as the OSID is scrambled, I'm assuming the file on there now is protected/proprietary is why the OS is scrambled.
I haven't tried sending anything in to support yet.....but I think that's what they had mentioned once here as well.
