21 Mustang GT 10R80 HELP!!!
Hello everyone, I have a base model 21 GT that does not have the toggle switch to change modes so I decided to try and turn them on via HPtuners. I started with the engine side by switching the use OEM to override and selecting the Drag/Sand mode. Wrote the tune and everything was great. It shifted hard like it was supposed to but I noticed the shifting map was still similar to just the normal mode. So I went into to the Trans portion in HPtuners and looked for anything the was specific to the driver modes. Once I turned everything over to reading everything from the Drag/Sand map I rewrote the the tune. When I started it up the check engine light was on. I scanned it but nothing came back. Once I got on the road it shifted from 1st into 2nd but was stuck in 2nd and it wouldn't even downshift or manually shift. I pulled over and reverted back to the previous tune. Still had the same issues on my way home which was maybe a 1/4 mile away. I got home then put everything back to the original OEM tune. Still has a check engine light with no codes read and it won't shift past 2nd. It also has long delay to go into drive or reverse from a stop and almost wants to spin a little when engaging. Any help would be much appreciated.
Thanks guys!
