I would like to overlay the wattage data from my wahoo element from the .fit file. Is this overlay type possible? Thanks for your help!
RaceRender does support FIT files, but if you can't open it directly in RaceRender then you should be able to convert it to a CSV file which is definitely supported. You may need to ensure that it contains a Time field, but I'd expect that to already be included.
Once you have the data into RaceRender, it should be very easy to add a graph/gauge such as a simple Text Data which displays just the number or perhaps a Bar Graph or 2D Graph which could better show how close to your max you are at any given time.
