I think my truck may have a tune in it already, would anyone be willing to share their stock read file so that I can compare them?
I have a couple different ones I?ll send it when I get off work today if it doesn?t read send file to support it?s probably been flashed and you will have to go to Ford or get unmarried to old tuning device
Here is what came from the truck
I’ll send you the file Im on my way home. I’ll compare it and let you know if it’s tow Street or Max
Definitely not stock it looks very clean not much timing no boost added probably daily driver
I thought the boost was still stock and I guess that explains it not having extra power. I'd like to increase the power on the truck as well, I need to start doing some reading to see what I can safely run without overspeeding my stock turbo and how much timing these engines like. Would a bit more timing help give me an increase in fuel economy?
Would you be willing to send over your stock pull for me to compare?
Is there a reason apart from emissions to keep the post injection event(s)?
My computer will be back today so I should be able to get you mine. But post injection is emissions I would only increase torque to fuel and set limiters to max and bump up fuel pressure about 5-7% so it shifts normal if not it will lug .
The repository has a few also
send me your email or email me
[email protected]
