Originally Posted by
10_SS
Yes, the VCX software itself (VCX Manager) is fine, installs no problems, at least for me. The problem comes when you try to install the hacked Tech2Win and MDI software which is hacked/crackked. That part can be a disaster, but you dont need that part to run TechLine. TechLine connectes to the VCX Directly.
I did make one mistake on that Ebay E67... because it was a much earlier ECU than what I told TechLine, I needed to use REPLACE, and I used Manual flash, which ended up corrupting the VIN since it was not from , which is not a show stopper, but once Techline flashes the ECU, it will not re-download the files to re-flash, as it thinks it's already flashed so it skips it on repeated attempts. So I need to use other tools to fix the VIN, which I dont have, but the VCX Nano itself works just fine,
Flashed my 2010 Camaro BCM to the updated OS, and also flashed the stock 2010 E38 in the same camaro to the newer OS, using Techline, both had no problems.
