Real Time Tuning Function
I just recently purchased a MPVI2 and Im new to tuning so I have been watching a lot of videos. Everything that I have found has told me that I need to convert to speed density enhanced os in order to use the real time tuning function so thats what I did. according to all the info I have found, there should be a wrench and lightning bolt at the top of the page that im supposed to click to start the function. Is this even still a function on the MPVI2 or am I reading and watching old information?
1 Attachment(s)
vve tuning not showing on afr error
Quote:
Originally Posted by
blindsquirrel
A video for a Gen4 E38/E67 with VVE will show you things that do not apply to a Gen3 P01/P59. It would be not quite as bad as watching a Ford tuning video then trying to follow the steps with a GM, but almost.
Download a random sample Gen4 file from the repository and look at all the shit that's different from your file. Then you might understand why you need Gen3 info to follow when working on a Gen3.
I saw the difference and watched the video which is why i wanted to verify if I can even do vve tune for this OS. Support Chris stated i can and to use my ve table instead of the vve table. I am in 1bar maf. Mass airflow sensor removed from scanner per instructions. I plugged in my older scan files to see what the scanner showed and something is not right as the afr error is not showing anything.
