1 Attachment(s)
need IPC E-quizzer id for os PWDJ2AZ
i have both stratagies and ecus licenced its just the PWDJ2AZ os doesnt have it defined in the parameters like my other os does and the ecm im using is the PWDJ2AZ so when i flash my other os on to it its a no start i know my other os E-quizzer id just dont have access to the one thats original to the ecu im using because of limited defined parameters for PWDJ2AZ os reason for swap was a my other spanish oak took crap after a short circuit happend in the harness because of a oversight i made after building and installing the harness a little to close to my headers just not much room in a 3v swapped fox you live and learn i guess
