MPVI2 None Pro + AEM Wideband
Is it possible to use my MPVI2 without pro features to read in the data from inline OBD adapter on my AEM 30-0334 Wideband?
If so, how would I go about this. No matter what sensor I add when I start recording the extra sensors disappear.
Tuner: MPVI 2 none pro features
OS: Windows 10 pro x64 version 2004
VCM Scanner: 4.6.3
Vehicle: 2015 Camaro SS / Manual Trans
Never mind about this first part I went ahead and got the pro features but there is still a problem with reading the sensor.
The sensor works properly but reading any data into the scanner still isn't working.
I have added X-Series UEGO Ratio 1 - 8 and repolled the car settings but nothing is showing up still.
The gauge itself is kind of funny to me. In the directions it shows there should be a menu item labeled OBDII but there is no such menu. All the other menu items are there according to the directions for the gauge. There is one menu item that isn't in the directions though and that is "CAn" I'm assuming that is the OBDII menu but there is only 16 parameters that can be changed.
1d01 through 1d16
I have tried all 16 settings on the gauge and disconnected / reconnected / repoll for all 16 settings and still nothing.
