I just updated to V4.0 and now cannot edit any of my already licenses tunes or read my vehicle. I keep getting an error that states Unlicensed interface. What do I need to do to sync things back up?
I just updated to 4.0, now editor and scanner won't open. Pop up box says "vcm editor has stopped working". I ran the installer again to correct any errors with same result. I then uninstalled, and reinstalled with same result. I'm running windows 7. Help please
Did you update your framework yet?
Just download it from Microsoft so you are up to date running the 4.6.1 that is required.
https://www.microsoft.com/en-us/down....aspx?id=49981
Getting unhandled exception errors when I try to open the trans segment of an ecoboost or try to compare the file to anything and view the comparison log.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
at ?.?.(Int64 , Int32 )
at ?.?.(Int64 , Byte , Boolean )
at ?..( , )
at ?..( ?, , Boolean )
at ?..(? ?, Boolean , Boolean )
at .?..ctor( , , , ? , )
at ..(IList`1 )
at ?..( , ? )
at ?..( , ? )
at ?..(? , , ? )
at ?..( , ? , ? )
at ?..( , ? , ? )
at ?..( , ? )
at ..??(Object , EventArgs )
at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
at System.Windows.Forms.ToolStripButton.OnClick(Event Args e)
at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventIntera ctive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(Event Args e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2563.0 built by: NET471REL1
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Assembly Version: 4.0.12.0
Win32 Version: 4.0.12
CodeBase: file:///C:/Program%20Files%20(x86)/HP%20Tuners/VCM%20Suite/VCM%20Editor.exe
Win32 Version: 4.7.2558.0 built by: NET471REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
C1.Win.C1FlexGrid.4
Assembly Version: 4.6.20142.844
System.Net.Http
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
InTheHand.Net.Personal
Assembly Version: 3.5.605.0
System.Management
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
C1.Win.C1Chart.4
Assembly Version: 4.0.20142.24286
C1.Win.C1Chart3D.4
{d7221b5f-1a96-4637-9f58-6b58f289b126}
Assembly Version: 0.0.0.0
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I had inquired about adding more parameters to the Chevy 2.0 LNF in regards to increasing injector drive current. This is possible on the 2.0 LTG/LHU. I spoke with Corey about this, and I was hoping these new parameters would be present in this new update....however I'm not seeing them, or am i wrong?
Just ran the update -- The installer uninstalled version 3.6, and the 3.7 beta as well. Did some logging & tuning today with Ver 4 and everything worked fine. :yay:
I'm new to this so this might be a stupid question, i have a 2005 Corvette C6 base (stock) and would like to buy the new MPVI2 interface but my question is do you have to purchase the VCM suite separately or is it included in the purchase of the interface?
regards
The suite is a free download. You can download and install it right now if you wanted to. In order to flash the tune to your vehicle you will have to purchase the appropriate number of credits as determined by this chart: https://www.hptuners.com/vehicles/
many thanks folks....:)
Support for VW Passat 2.0 Turbo 2009-2015?
Are the legacy supported vehicles no longer going to receive software enhancements, new accessible and adjustable parameters to the existing software?
I'd really like to be able to do/see more to the Caliber SRT and Neon SRT.
When will the upgrade from the mpv1 to the mpv2 be available
When will the newest update show all the adjustment options like the older versions? Will they be coming in an update file? Comparing my file (vs 4.0.12) with mpvi2 to a buddies older version and mpvi1 it appears I am missing some of the options and tables
Nothing is different between mpvi1 & mpvi2 files, we've moved alot of tables to make them better organized but we didn't remove anything.
