2 Attachment(s)
14 CTSV rich WOT pull in 2nd gear vs 3rd gear
14 ctsv m6
-airaid
-ported blower
ID850s
-test pipes
-2.35" upper
Any of you guys experience having a more rich WOT pull in a lower gear than higher? I have already got my ITT table dialed in for the higher temps so i'm not overly rich while heat soaked. Normally my fuel is pretty well spot on everytime i've logged, but this time I noticed my injector PW went much higher towards the end of 2nd gear vs. the end of 3rd gear. I did notice that i got up to the 12300 hz range in 2nd gear and not in 3rd so maybe i just need to take a few percent out of my maf curve in that area. This was right after I flashed the car though...not sure if that had anything to do with it as I've read that you should drive around for 10-15 min to let everything stabilize. Ignore the small amount of KR at the end of 3rd gear as I've already got rid of that. Any thoughts/suggestions would be appreciated. The WOT pull starts at the end of the log
On a side note it looks like that my maf is maxing out at 655 g/sec. Is this normal for Gen 4s? I have never noticed this before
Attachment 102152
Attachment 102153
