PSB-1 Wideband
I am using a innovate PSB-1 wideband. I have the MPVI2+ (not pro) and I am trying to setup the wideband to data log. I have it connected via a serial to USB and successfully can see a reading while scanning (using the external input). Ok now my issue, it is reading 505 (in what value I do not know) on the scanner when the gauge is reading 14.8. Does anyone know how to correct this?
I tried reading the sticky's and didn't seem to find the answer. Thanks.
I'm having the exact problem after an automatic VCM scanner update last summer. Let me know if you find a solution, I've tried every forum and facebook group and no luck.
I am having the same issue
