1 Attachment(s)
2014 Ram 5.7L Cam, L/T headers, CAI, MDS delete, first time tuner, wanting to learn.
Hi completely new to HP tuners, looking for some help learning and tuning my truck. Been a dealer diesel tech for 24 years.
Replaced the Stock Cam with custom Comp cam & Phaser limiter, hellcat lifters, AFE L/T Headers W/ Cat's, AFE CAI, Polished heads, new stock valve springs and custom pushrods, MDS plugs, replaced mechanical drive fan with electric fan and installed 180 degree t/stat.
Engine starts and idles well, will stall when comes up to temperature.
Have done some reading (please correct me if I am wrong) need to change Cam timing values and VE table values, delete MDS and set new cooling fan temperature values to start.
Cam specs @104 degree centre line
Duration @.050" INT 210 EXT 222
LSA 112 degrees
Valve timing @ .050"
Open INT 1 BTDC EXH 51 BBTC
Close INT 29 ABDC EXH 9- ATDC
Does anyone have a tune for a similar set up that I can compare with and emulate to start off?
Once idle is corrected, is there a recommended progression for the tune? it sounds like many things in life, in that there is more than one way to skin a Cat.
Are there any manuals or reference material that someone can recommend to have a better understanding of the tunable parameters and how they correlate?
Any help is appreciated, attached is my stock tune.
Thanks in advance.
Rob
