2 Attachment(s)
2012 Mustang 47lb injector help
I installed a set of 47lb injectors that are supposed to use the exact same data as the LU47. The trims seem further off than I was expecting. Can someone please confirm I have the injector data correct. Other than the injectors the car only has a cat delete.
Attachment 103584
In this log you can see it goes from adding quite a bit at idle to pulling through the mid rpm/throttle and then being pretty close at WOT.
Attachment 103585
I don't have any real experience with this, but from what I've gathered on here, is that the trims should be closer than this if they were exactly the same the LU47. If my data is correct the LU47s would have been closer.
