In case you guys missed the announcement, the latest beta has support for the new 2017 6.7L Powerstrokes.
Nice! send me the beta plz!
You'll need to request the beta by sending [email protected] an email requesting it. If you already have the beta, you just need to visit your customer page and download it again.
Great to hear Eric!! I am new to HP tuners, and considering attempting your platform for my 2017 6.7 Power Stroke. What kind of parameters/how many can I expect accessible so far with this beta release? Just wondering what to expect if I purchase the VCM suite to use on my truck. Thank you!
You would have to get your truck flashed with a removal tune first, then read that out with HP and make changes to that one. Well that's what had to be done on previous model year 6.7s
Eric, Does the 2017 F250 DSL support changing the TPMS parameters?
When will data logging above SAE pids be available for 17s?
Pids I'd like to see.
Main Injection Duration
Main injection fuel quantity
Main injection timing
Pilot and Post 1&2 Duration
Pilot and Post 1&2 Quantity
Pilot and Post 1&2 Timing
Rail pressure actual and desired
PCV & VCV Current
PCV & VCV duty cycle?? if possible...
VGT Duty cycle desired and actual
Boost
Exhaust Pressure
Throttle position
ECT & EOT
EGT Temps in egr, and emission system
Exhaust Differenctial pressures
DPF load (parts per million)
SCR Injector cycle
Intake air temp
Trans fluid temp
Trans gear
TCC lockup
Trans line pressure
Shaft speeds
Vehicle Speed
Anyone have a full PCM/TCM stock read?
here is a 2017 stock read
I cant move engines parameters.
Is it possible to adjust tire size on the new Beta version, i upgraded my truck with 37" inch tires and it still thinks it?s stock !
I just got a 2017 F350 6.7 Diesel. Need to adjust the speed limiter to a lower speed, cant get the truck titled here in Norway without a speed limiter set to 55 MPH. I got a read from the forom that is from a 2017 and this show the limiter in the speedometer tab. So i used 4 credits to get mine that also a 2017 but there is no speed limiter that show in the speedometer tab. Just sensor calibration and ratio.
is this somthing I can expect to get in a near future. And is the differnces on the computers on 2017 super duty.
I asume i cant license the one I upploaded and use that instead, is aparently some differences
