First time trying to tune a gasser with HPT, got a 2017 2500 Silverado with the 6.0 engine. Was wondering where I should start for adding power and also the trans side. Vehicle will tow mostly. Thanks a bunch.
This is the file I read. Comparing it to a stock file from the repository, it has some differences.
You can make it more responsive but there isn't any real magic horsepower to be gained, nothing you are going to notice for towing anyway. You need to actually mod the engine, like different camshaft or add a supercharger if you want more grunt for towing.
Your file from a repository file can always show minor differences depending on what version of the calibration it is, some trucks could be earlier built or later built with different calibration changes because of that.
I can't edit your tune but I'm sure others will maybe be willing to help.
The 6.0 Gen 5 stuff actually picks up a ton with tuning.
They often have exceptionally long PE timers, the MAF is often way out of calibration at higher loads, and timing of course.
This one looks like it was modified already, but could be done a lot better.
Question about the maf, which way is it out of calibration? The intake is stock. With gassers, re-scaling the maf will either add or subtract fuel? This is how it works on the diesel side but how will that equate to more power for a gasser? I'm assuming they run a bit rich from factory at high loads so you want to lean it out a bit?
They are typically very lean. like 15%+ with the stock airbox even. SO add. But you should be measuring yours and tuning around what your truck is doing.
They feel like they pick up 50 rwhp with a tune. Not saying yours will.. They are not common compared to the 5.3's and 6.2's but the few I've done have really woken up.
Pretty surprisingly poor OEM tunes in them.
Something I'll add.
For a tow rig I like to get rid of that big spike in the VCT angle tables.
Attachment 144223
Compensate for the changes at VCP spark. This can be done in either the VCP table itself or the base spark. In the VCP table, copy-with-axis 3400rpm and up then paste-add into the Low Octane table. Interpolate the columns between the horizontal bounds. See the trends?
Attachment 144224
Do the same for Hi (watch MBT!). Afterward, zero out the VCP table.
Attachment 144225
Of course, verify changes through logging.
Quick example attached:
