Quote:
Originally Posted by moregrip
never heard back on this, noticed there are some help files "getting started" sections not there.....any help? thanks :)
Did you uninstall 1.7 first?
yes I did, only thing on here now is 2.0.16, should I uninstall then reinstall again?Quote:
Originally Posted by Keith@HPTuners
when you click that help icon does it bring you to the 2.0 help files?
It should say "Whats new in vcm suite 2.0" on the main page.
No, it says "Whats new in version 2.0", it has no data in the getting started section except connecting.Quote:
ok thats right.
Keith,
I just received my software on Friday and I tried to read my pcm today and I get the same error message that 99Zee28 had. I also have EIO and the CD I received in the mail says it is version 2.0.16. Could I get the update you sent to 99Zee28 so I can try it again. I'd like to read my pcm before I put the car away for the year so I can start learning about all the parameters and stuff. Thanks.
Nick Schultz
Edit: Hey Keith I e-mailed you about my resolution. I forgot to have the black EIO box pluged in between the diag port and the lap top. I only had the one cable connected, not both. Thanks for the quick e-mail reply though. Seems like so far it's A+++ customer service. Great job guys I can't wait to start learning more.
Nick
Got mine yesterday :cheers: However , I had to endure TWO VERY FRUSTRATING hours of changing cables , reading the help file , checking everything and the result I still got that darn " The interface was not found or is not responding. " message :banghead:. Then as I was about to give up I read " Verify that you have no other software program running that uses the COM ports (Palm Pilot, UPS, Etc) " and remembered a thread here about the same. I don't have a palm but I have an Imate Jasjar Communicator that syncs with the laptop. It uses USB so I didn't think it would matter. Anywho I check the program just to be sure and sure enough ( Program is MicroSoft ActiveSync ) it is using COM1 :banghead: even though I'm connecting via USB. So I switch it off. Try again .... nothing ???. So in true windows fashion I restart ..... Then Voila :cheers: :cheers: :cheers:. I'm in business. ;D . Downloaded my stock bin . I'll be going for my first scan today :secret:
P.S. May I suggest the above problem ( Sync Software ) is mentioned is the Help File. Just a suggestion . I think it would help . :)
Quote:
Originally Posted by 99Zee28
I had the same fault when i installed 2.0 . i found the fault to be my pcmcia to sieral adapter which i had to use with 1.7 because i had problems with usb.
whent back to usb it now works perfect
