1 Attachment(s)
What limiter is this and stock wastegate
I did a stock pull and I hit 133mm3 wide open at 25psi boost and now I did one with boost limiter off, baro off, and torque limit and I hit 125mm3 max with 33psi boost?! What limiter do you guys think im hitting? Is it the smoke limiter EQ because I dont know how that one works, is the higher the number the more its limiting or the lower is the most its allowing. Like if I go to 4 on the whole table will that disable it?
I thought the stock wastegate opens at 25psi how did I get to 33psi?
Attachment 85737
