Re: Tach signal multiplier?
i'll have a look into this one. Interesting request :cheers:
Thanks a bunch! This would be a great improvement over adding on a dakota digital frequency converter, or taking apart the tach and modify the capacitor/resistor circuit
Any word on this guys? I'm close to hardwiring my car, and would love to exclude an add on signal manipulator... Does it look like a possibility? Thanks in advance :cheers:
sorry nothing yet. i will look at it again next week.
FDLS6, one thing to check is I think that the ABS modules on newer vehicles also pull the tach signal from the PCM.
During my swap I tapped off of that line but do not have ABS anymore.
I have been using a dakota digital tach adpater for a year now and there is no latency in the device at all. I am using a 97 F-body cluster and the tach is near-instant.
However, if you pull up the scan tool and only monitor the RPM PID, you will see that the scan tool actually refreshes faster than the pre-98 gauge clusters for the f-bodies. I found that rather interesting. Thats actually how I found out my tach has a little lag in it from the factory.
Has anyone tried BakerElectronics TDS? I was told about it a few weeks ago. I'd rather use the HPTuner than the TSD but the TSD would "tide" you over if you were in a bind to know what the RPM is.
TSD (tachometer signal divider/adaptor) module availible to convert the LS1 tach signal to a standard type 4, 6, 8 or 12 cyl tachometer signal for only $40, much cheaper then Dakota's $79.00 one.
www.bakerelectronix.com
I was wondering if you guys could add an adjustment for the factory tach...would that tie into this too? My tach (and many 98s like it) is off by 150-200 rpms at all speeds. I would love to fix it.
