Is there anyway we can have FICM output voltage added to the channels list?
There are several standalone scanners that plug into the OBDII ports and monitor this.
would it help if i open a ticket on this?
Yes I would open a support ticket. Ficm voltage is supported on some calibrations.
i ended up opening a ticket. They said they would get with engineering to see if they could do it. never heard anything back.
would any of you guys run a scan and see if FiCM main voltage is reading correctly. Support tells me it is setup properly, but mine reads 13-14 volts.
Obviously since the voltage needs to be above 45 volts, my truck theoretically shouldn't run.
Any updates on this? it would be great to look at ficm voltage
nope. they responded back to me saying they have it set up properly. I sent them a scan showing them it didn't work and they just quit responding to me.
I got fed up asking with no response, so I bought Scanguage for my truck. It pretty much reads everything I need to scan while driving.
