Injection Timing Calculator
If you are reading/using this, do not PM me about it. I am no longer supporting this. Feel free to use at your own risk, but all pms regarding diesel tuning will be deleted.
I have never been able to make the injection timing calculator made for hpt work(For anyone who found the other post about injection timing calculator, all it does is invert the hpt tables so you can use the efi live calculator, I did not realize this back then so I created this one). So, I took version 2 that Josh made and reworked it for hpt myself. If you already have a working calculator, this one is probably no different. I just reworked the tables to correct the axis, and corrected a formula mistake made by Josh in the LMM table. I did considerable error checking against Joshs table and am pretty confident it is correct, but use at your own risk. If you come accross any problems, I would appreciated the feed back to correct it. Enjoy.
Website has been updated, spread sheet is now attached.
Edit:fixed formatting in lmm table
