Need Help Camaro 2016 2.0
Quote:
Originally Posted by
lt1z350
So they got one right. I have tuned around 20+ 2.0t in camaros/ats/regal and others and none of them take the same settings. They don't take to a canned tune at all and why the diablo sport hand helds were blowing up 2013-14 ats left and right. Trifecta tune is a joke I have a few on file that I pulled from cars after they put a new motor in them and needed the tune fixed. They are actually worse then zzp which is really bad in their own way. Don't recommend what you don't know just because it worked with one customer doesn't make up for all the other cars they blew up or customers they abandoned after couldn't get the car right. I fixed a lot of cars for free due to that company and now they do it with the cts v sport another hack job that eats spark plugs as some cars record 9 degrees of kr and trifecta tells them its ok and normal. Fact is you got lucky you didn't have any issues as most do. If you have looked at the tune and added to what they did and think its ok your worse off then you think and have no clue how to tune a 2.0t
Im not sure what you consider potent but got a 9 speed Malibu running in the low 13s high 12s in winter @109. The best trifecta tuned ats I ever saw posted was in the 13s @100-102 mph most guys that tune on there own stuff hit that easy or even 104 mph. I have camaros down pipe only and tune running mid 12s add meth 12 flat. Last 2.0t on a dyno made 368whp on the stock turbo 2017 camaro with a few bolt ons on 93 that one does have a front mount on it. Most of these canned tunes are much faster just feel like it because they disable the tm make it shift harder and over boost it in the mid range make a lot of torque then the manifold temp sky rockets it gets kr pulls timing and falls flat on its face by the 1/8 mile. they feel punchy as hell but don't run well and most will get a piston in due time.
Hello, if you could contact me on a tune ect... Sounds like you know what your doing on the 2.0, i am looking at gettin a zzp tune
