1 Attachment(s)
Is the single wire class-2 line required for flashing high speed GMLAN ECUs?
Hello all,
I am making a stand alone harness to do some bench testing / flashing of an E40 PCM. This particular module is from a 2006 GMC Envoy XL (E40 PCM on an LH6 motor.) All I want to do is connect to, and flash, the engine controller in a complete stand-alone environment. No transmission controller or body control module will be used.
The wiring diagrams I have for this vehicle are a little vague and even though the class-2 line is connected to the DLC / ALDL / OBD-OII port, I'm skeptical that I actually need it. Was wondering if anybody else has had experience with this.
Thanks.
Attachment 84768
