2 Attachment(s)
Can someone please check out my first tune
Thank you for any help.
If does run, motor not driven on the street yet, only running it garage.
C5R block
Callies dragon slayer 4.0" crank
Comp star rods (made by Callies)
Weseco pistons -8 cc
ETP 225cc heads , ported to 232cc by WCCH 2.12 intake 1,94 exhaust valves, .700" lift valve springs
Cam 255/257 .624/.624 lift on 111 +4
Super Victor intake
105mm TB with custom elbow
Stock rockers
LS7 lifters
ported oil pump
dual roller timing chain
Fuel
255L intank pump
60lb injectors
custome feed/return lines with regulator
Tranny
FLT level 6 with hardened input/output shafts
Yank SS3600 stall
SFI flexplate
Rear
3.55 gears with 30 spline axles,heavy duty posi unit
That should do it.
