Originally Posted by
Paulo2
I am new here, so HI.
I am currently getting a 2016 6.4 Hemi ready to go into my 2006 300c. My question is, should I use the ECU that came with the 2006 300c 5.7 Hemi or should I use the ECU that came with the 2016 6.4 Hemi? The only mod is a stage 2 Comp Cam kit.
I understand that I will need to change the crank sensor and pickup if I stay with the original 2006 300C ECU, and I am not sure if I can take advantage of the cam phaser and active runners. I am prepared to lock the cam and active runners. Also I have a spare 6.4 harness to get bits and pieces from if required.
If I go with the 2016 ECU that came with the 2016 6.4 Hemi, can I get it to work with the 2006 300C?
I have recently purchased a MPVI2 and the The Tuning School Dodge Beginners HP Tuners Course. So I am on a step learning curve.
Opinions would be greatly appreciated. Also is there anything else I need to consider that I may have over looked?
Thanks in advance
