MPVI2 RPM signal output to Dynojet PowerCore software while data logging - How?
Is there a way to output vehicle RPM (tach) signal from the MPVI2 to Dynojet PowerCore software via CAN or Bluetooth?
I am trying find an easy way to get a clean tach signal to Dynojet Dyno and datalog HPTuners while making a dyno run.
I can connect via an ELM327 and get a tach signal to the dyno, but I need to have the MPVI2 connected at the same time to datalog.
Maybe I missing something and there's a better way. I tried searching the forum and came up with nothing.
I have an OBDII Can adapter plug that can be plugged in between the MPVI2 and data port. This is normally used for a Wideband signal input while datalogging with HPTuners.
Is it possible to use this for an output for reading vehicle RPM CAN data into the Dynojet PowerCore software?
