As above, it wont send to a Gmail addy, have you got another ?
[email protected]
Cheers again
Could I please get a copy emailed to me? It will not open when I download the link.
[email protected]
Thanks!!!
i have to open it out of the folder it comes in, cant seperate exe file
I've sent a copy, but yet again it's been rejected by a server. you need win zip or similar to unpack it and then use it from there
Here you go! Youre welcome...
https://drive.google.com/open?id=19L...gxv43MrwEHD0TJ
Well that didn’t work...
Any way to email it?
[email protected]
No luck with Gmail either, so I've added it to my dropbox account and sent you the link via that Gmail, I hope you can get it that way ? john
[QUOTE=jonathan8186;588108]Well that didn?t work...
[email protected][/QUOT
https://drive.google.com/folderview?...gxv43MrwEHD0TJ
Every time I get the parameters to where a car is over 380hp it gives me a "Data in Logic Error" If my stall speed gets above a certain amount or my HP goes above a certain amount. Any thoughts?
Is version 1.37 the most recent version?
Has anyone used this on a gen v? Like a 2014 Silverado 5.3 with the 6l80e?
Yes it works fine. However I also tried setting my wide open throttle shift RPMs then putting the wrong tire size in the gear/tire wizard hit apply then I put the correct tire size in and hit apply and then all my shift points were corrected to where I wanted them. :shrug:
I'm sorry I see what you mean now. You can't go past that first page.
Can someone email to [email protected]
2017 silverado
What shift slope did youb use for 2017 silverado lt4 throttlebody?
