Oh... Bosch. Don't do that, it's not a VW. Bosch doesn't do so great with stuff where they weren't the OE supplier, specially with O2s and extra-specially GM O2s.
ok i just madevthe change to the map set my ve back to my starting point and then failed the maf and took it for a drive to get some ve data
Ill see if i can find some denso or acdelco replacements
this is a run with the MAP values changed with the MAF ok
well looks like my ve data is pretty crap. its too hot outside at the moment ill have to give it another shot tomorrow
Looks like the GM O2 sensor is a 213-1149 do you have any recommendations?
denso downstream left 234-4286
denso downstream right 234-4651
NTK downstream left 21548
NTK downstream right 21514
Either NTK or Denso, a lot of times one of those is the supplier that gets repackaged into ACDelco boxes. Stick to one of those three and it's OK to choose by lowest price.
No I always buy off Amazon, always the ones with the 'Amazon's Choice' label in the corner. Amazon is a large, successful company and I trust that they have true automotive experts on staff who have thoroughly evaluated those products to make sure the 'Top Best Raceing'-brand sensors really are the best.
Does anyone have a link to a good writeup on tuning with a WB o2 sensor. I'd like to know how to get it all setup and wired in.
Do you have Pro Features?
This might leave you with lots more questions
But once you have your Wideband logging in your channels list you create an error log with it just like you are doing with your o2 sensors. You can use your o2's for closed loop and your Wideband for PE/WOT at the same time.
Or strictly use the wideband
I included the user manual so you can see how they show you to wire in the wideband
They include numbers you will need to transform (as all other manufactures do)
https://support.hptuners.com/hc/en-u...tion-and-Setup
https://www.youtube.com/watch?v=3TQdrTMnljI
Yes I have the pro Features
