TPS is .86 eng off, at idle .75. tuner says it should be closer to .20v. Have a Fastman 84+4 on it, but the stock TB reads close to the same. Throttle relearn doesn't change anything. Holding blade closed readings are .49v stock TB, .55v 84+4. Normal? Engine responds to changes in airflow tables below the .75v range.
Attachment 85303
Attachment 85304
