I'm using the MPVI2 w/ the Prolink.
I was able to get AFR working(because I was unable to get Lambda to work). Using Logworks I changed it to 0 volts 10 AFR, 5 volts 20 and used .5 +10 in HPT
I went back and re did the scaling for Lambda and apparently I typed something in wrong before.
KOEO, it reads fine, when I start it the WB controller gets screwy and doesn't turn on. I'm going to change my power/ground wiring to the W/B and see if that fixes is.
