1 Attachment(s)
I hate gen3 idle tuning.... cold start help
I am battling to sort out the cold idle on my stroked big cam (24X/24X) ls3 (cable throttle). I have got the BRA pretty sorted, I adjusted the IAC effective area a fair bit, it was way out (as well as drilled the throttle blade to get IAC readings around 60 at operating temp). I believe it must be one of the decay rates or something. If you look at the log when I fire it up its 26 seconds before it dies and I hit it again and its another 26 seconds and it dies again..... Im not sure what is up. It is also idling a fair bit above target when it first fires up for a while, not sure if that is due to after start enrichment. Not sure if the VE table needs tweaking, due to the long tube headers and cam overlap, the wide band is useless. Please help! im going bonkers!
