High Ambient Temp after ReFlash - Gen V LT1 & LT4
I've noticed after a reflash on my 2018 Camaro SS (LT1) the ambient air temp will go very high 118 degrees when it's only 80-90 degrees outside. This changes the VE fueling (if temp enabled) and I don't recall it doing it 1yr ago when I did the S/C or 6 months ago when I changed the tune a little. It takes awhile for it to come back down to actual temp for proper fueling to match the actual tune parameters. Is there a fix for this or something HpTuners can look into? Or it's just a ECM reflash thing that happens?
