When i increase the rpm tables it changes it and i write to truck but idle speed stays the same. Whats wrong or what am i not doing?
Can you post your file please?
here is my log and my current tune.my fuel trims seem high to me?
Where is the wideband input? Everytime you hit wot, there is a lot of knock. STFT's are high, so it must be running lean.
I don't have a afr gauge yet. How do i adjust to add more fuel
Attachment 102241
I have adjusted your VE Table and Maf based on your log. Your Long terms and short terms are all over the place adding up to 25% fuel. I smoothed out the VE table and increased it accordingly. Its not going to be perfect but should give you a starting point. load it up
Thanks alot... Gonna write it and do some logs today
Had some other tuner look at it to and he said
You’re getting 7 degrees of knock retard and total timing is only at 15 degrees when that happens. That 6 liter is capable of pushing 26 degrees on premium fuel and 19-20 on regular.
You need to download vcm beta And use that
What are stft and ltft supposed to be at
downloaded bete and it opened it...hey someone told me to copy values from a certain tune over to mine..i did and have new logs...if you dont approve seems how your helping me let me know and ill go back to only what you tell me.ill wait to write your update till i hear from you first
Attachment 102257
Load this file up and get some more logs for me please. If easier you can email @ [email protected]
