5.0 Coyote Swap PCM Reprogramming
Hello Everyone,
My Project is a 2014 Ford Expedition with a 5.4L 3V and a 6R80 Transmission. My Plan is to install a Gen 1 5.0 Coyote from a 2014 F-150, so the question comes down to controlling it, I could buy a standalone PCM and body harness to run it, but then all the other modules on the vehicle (ABS, TCS, Instrument Cluster, ETC.) won't be fed all the information they need from the vehicle PCM. Both the Expedition and the donor F-150 run the same Physical PCM but with different software, and likely different pin outs.
My desire is to reflash the F-150 (5.0) PCM with all of the Body control module software from my Expedition PCM. and then just run the single PCM as the vehicle would if it had been produced with the 5.0 in it.
Is it possible to look at the module overview in Ford IDS software to obtain the correct vehicle modules software Versions from the Expedition PCM, and then reflash the individual softwares for the various modules into the F-150 PCM while leaving the 5.0 Engine and transmission control software the same?
I truly appreciate your help, even if it's only answering my ignorant questions, or pointing me to someone who can help.
Thankyou all for your Time, Brett
