3 Attachment(s)
Getting Service ETC and limp mode with no DTC's with bigger TB
Hey guys,
I have recently upgraded to the BBk 100mm TB and installed it onto my 6.4 NA with the Edelbrock Victor II intake. When driving, I get the ETC warning flash up and disappear numerous times and finally it sticks and enters limp mode. I can turn off the car, turn it back on and everything is goes back to normal. I spoke with a rep from BBK, they think the issue is this:
"The home position senor on the tps is trying to adjust the flap at idle to achieve proper idle rpm and is unable to do so. You will need to look at the idle tables and see how you can adjust throttle blade angle in conjunction with percentage of throttle engagement."
First log file shows the blip in TPS at the 5 min mark, second log is of my current tune where it also has happened, and my current tune. Any advice is appreciated.
Attachment 93089
Attachment 93090
Attachment 93091
