3 Attachment(s)
2010 Challenger 5.7 A5 low WOT spark timing
For some reason, the WOT spark timing is much lower than the WOT Base spark table. As you can see, I also set the WOT Thermal spark table and the VVT MBT tables to match the WOT Base spark table. Also changed the MTB Base table to match. The Tip In Throttle spark table is zeroed out as well. The ECT & MAT temps are low enough not to pull timing as well.
Also the scanner has no torque management, or spark source pids using today's beta. Also tried repolling for supported pids, and deleted the vehicle folder in the scanner folder. The only work around, was to set the minimum spark to the timing I wanted.
And yes. the traction control is turned off. Using 92 octane fuel.
Russ Kemp
