Transimission Heat Issues on Gen V trans and TCC explanation needed
I have a 68 Camaro with a L86/10l80 trans and I just started driving it more and the first long drive I higher than normal temps around 195 degrees before I got home. This temp could have kept going up but it held strong and only dropped around 1 degree, other than that it just kept increasing over a 30 min drive of stop and go and longer 50mph roads. I know this temp is not too high but I dont know where it will eventually stop and I don't want it to be an issue while I'm out and about. My wifes 2018 with the same motor and trans is hard to get to 180 degrees and drops down to the 160-170 range once it gets that high. Also on these newer transmissions I think they have a temp controled pump so it doesnt turn on until a desired temp but I do not know the temp.
The car has a swap harness and the way its wired is different from other swap harness builders like Speartech. The harness has a brake wire that is to see 12v when brakes are applied but other harness builders want to see 12v when brakes are depressed. I'm wondering if the converter is doing something strange and causing heat to build up. The harness builder said this is just how he sets them up and he has tested it and the TCC receives its needed signal either way, pressed or depressed. VCM scanner shows brake applied when the pedal is pressed so I'm assuming its working correctly? To help troubleshoot this I'd like to know if someone could explane the TCC function on the newer transmissions, mine in particular and tell me what PIDs to log and check for? Only PIDs I'm seeing are the TCC line pressure, TCC slip, TCC desired slip and they read in RPMs the converter isnt just locked or unlocked like older transmissions.
I believe my radiator is sufficient to cool the trans but I'd like to explore the TCC first.
Another issue is the trans just threw a bunch of solenoid out of calibration codes and this could have caused this heat issue too. These were not present prior to this. I tired to clear them but they came back. I tried a fast learn and it aborted each time I started it. Other then the codes it drives like it did before.
I know its a lot to take in but any help will be greatly appreciated, thanks!
