I can't seem to find out what's limiting this car above 5500 rpm. Trying to get the hp to go up with rpm but keep getting limited
here's the log and file
It may have something to do with the changes you've made under Exhaust --> Temperature
I'd recommend not changing the Exhaust Temp and Flange Temp VDE tables and only adjusting the Flange Temp Inverse table. I'm not a 100% sure that will solve the issue, but that's the only thing I see out of place.
I've attached an adjusted version of your tune just so you can see the changes i'm talking about. Hopefully this helps!
Thank you, I ended up figuring out it was the driver demand table, I wasn't logging one of the pids I needed to see that
Can you explain what you did or logged please. I’m
Having the same issues.
Thank you.
