2 Attachment(s)
Command throttle VS vehicle speed
I have this issue I cant figure out. This is a ls swap in an old truck. stock 4.8 with a 6l80, ecm is an E38 from a 2010 1/2 ton truck with a 5.3 and 6l80
What happens is the command throttle is around 3% with the truck warmed up in gear. I let off the brake, dont touch the throttle and when the vehicle speed hits 2-3mph the command throttle jumps to around 10%. It does it in drive and reverse, every time and it needs to be fixed. None of my idle rpm settings are anywhere near the 900-1000 rpm thats its going up to.
What am I missing here?
Attachment 94647
Attachment 94648
