trying to figure out wiring and what the formula would be for this wideband using 0-4v?? Using pro link with MPVI2
Same here. No luck tried a bunch of transform equations, sequence of plugging into laptop & starting scanner, etc. channel shows up until I start logging then disappears.
anyone find anything that works for this??
You actually already have all the information you need. It's a 0-4v sensor that goes from 10:1 to 17:1
Therfore, (4volts-0volts)/(17:1-10:1) = 0.57143
That becomes your slope of the line then you add in the offset of 10:1
(Input/0.57143) + 10 =Output
Check this out
https://forum.hptuners.com/showthrea...R-and-EQ-ratio
