1 Attachment(s)
4l60e no automatic shifting up or down.
Long time stalker, first time poster.
Rebuilt the trans with Transgo HD2 kit. Trans came with the car so built it while having a TH350 in it.
Heres the problem. If I have it in 4th it will not downshift when I come to a stop to start in 1st. Actually it works like a full manual valve body now except that it will downshift when I get on it. Whatever gear I have it in is where it stays. Shifts very good using the shifter. I have replaced every solenoid and the scanner shows MPH but occasionally the wrong gear. I have also had an intermittent VSS code, but again the scanner shows speed.
Ill try to attach a file so you gurus can help a brother out if I messed up a setting. BTW I did use the Bluecat software for my gears (4:10) stall (3600) and tire size (28) starting with a base 2002 Fbody trans tune which this trans is from by the stickers. I have a 2004 GTO P59 PCM if that makes any difference.
Thanks.
