couple questions regarding 2.4 cavalier
a buddy of mine wants his 2.4 cavalier so I've been looking over stock files to get a feel. Most of my experience is with LS and 3800 engines. I have a couple questions if you don't mind.
1. when does the computer use double fire injection vs single fire injection? so I see, the computer uses singel fire from the factory. Any advantages to running double fire? From what I've read so far there isn't.
2. what aproximate timing/ af ratio should I shoot for during wot on a near stock engine? a/f looks to be 13.0 and timing well into the 20's. Can't imagine there is much to be gained on a stock vehicle.
3. the pe vs map vs rpm table starts at 120 map...this engine is not yet boosted so It will see between 90-100 map at wot. Will it just use the 120 column? I'm assuming that's the case.
any help is appreciated.
