5 Attachment(s)
2003-2007 Cummins 5.9L: Major Update Released in 3.0!
HPTuners has listened to your feedback and have released the first major update to the 2003-2007 Dodge Ram 5.9L Cummins since our first to market release in December. This update includes 400 new tables, scalars and switches. Notable highlights include:
- Renaming and significant reorganization of existing parameters.
- Diesel fueling is now broken out into its own tab to allow for better organization of individual parameters.
- Parameters have been moved and regrouped according to injection event, purpose and cosmetic layout in VCM Suite.
- Added high idle feature switch with adjustments. Minimum, maximum and increment RPM are fully adjustable. When activated and the set button is pressed at idle, each time the cruise Accel or Decel buttons are pressed, the RPM will raise or lower by the increment amount to the min or max.
- Added 2005 model year O/D off feature. When enabled, on the O/D off button will actually turn off overdrive instead of actuating tow/haul mode. This works in conjunction with the latest OS which is already included with HPTuners.
- Improved PCM write algorithms for more consistency and reliability.
- Added category and settings for the part throttle governor used on automatic transmission vehicles.
- Added new category and settings for the all speed governor used on manual transmission vehicles.
- Added new settings and significantly reorganized the limiters section.
- Added new category and settings for the high speed governor.
- Added new category and settings for electronic fan control.
- Added new category and settings for alternator control.
- Added new settings for turbo wastegate control.
- Added new settings for torque management.
- Added brake torque management RPM limit.
- Added various new settings for injection timing.
- Added new settings for injector hardware control to tune for new injectors.
- Added many new settings for fuel pressure actuator duty cycle control.
- Added lift pump run times.
If you have any questions please feel free to ask here!
Attachment 58380Attachment 58381Attachment 58382Attachment 58383Attachment 58384
