Originally Posted by
VFL77
It should work if you're using a recent beta version. All the torque parameters (~10) return values for me.
Some things that will affect parameter logging that I've seen are
. other things plugged into the OBD port at the same time (disconnect them)
. HPT dongle lockup during the engine start cycle (plug it in after starting the car)
. laptop... (CTL-ALT-DEL)
. Select "Repoll for supported parameters" under the Vehicle option of the scanner programme (this seems to be less of an issue with the MPVI2)
